I seem to be in the mood for modelling at the moment, and I'm making progress. I've been terraforming with expanded polystyrene, covered with papier-mâché for the gentler hills, and to be attacked with plaster to make cliffs (left hand side of the layout). I'll use some of the Woodland Scenics moulds to (hopefully) create a good rocky appearance, and some will also be used to create outcrops elswhere. I want to make an unlined tunnel in the cliff face, so I hope I get the hang of things!
Pictured here (and generally being played with today) are two-thirds of my narrow gauge loco stud, on the left a Liliput ÖBB class 298, and on the right a Roco Henschel HF 110 C. Both have additional details to be added, and the Hencshel has been repainted from the red livery it was supplied carrying in the start set. My other loco is an ÖBB 1099, an electric type which came with the coaches the 298 is hauling. Being a single baseboard layout, there is a strong temptation to string up wires. I must resist, as I'm adamant that this layout is set in eastern Germany! The ÖBB coaches will be repainted at some stage, representing some coaches bought in by the fictional private preserved railway the layout is meant to be.
Lastly, a general view of the layout from the other end. I'm still not totally sure what to do setting wise, I can't help but feel that the back would look better as a hillside than low relief buildings directly againts a backscene, but then there will be only a couple of buildings on the whole thing, leaving the station somewhat unjustified! Your opinions would be welcomed.
Cheers
Rich
